Magenetic GPS antenna and ground plane
I found this little tip… If you are using the magnetic GPS antenna that comes with some of the Peplink products (ACW-232) and you are not placing it on a metal surface… Make sure to place it on an electrically conductive ground plane. While the antenna works without the ground plane, it’s accuracy is dramatically improved with one. I found the tip on the 5GStore…
ScreenHunter_01 Sep. 20 02.09
