Is there any plan on the BR1 to support NB-IoT and/or LTE-M ?
Dana
Dana
Dana,
Attached is Vodafone’s view of NB-IOT and LTE-M.
TL;DR/Summary:
Vodafone already has > 2500 UK masts enabled for NB-IoT (April 2019)
Deployment is ongoing in the LTE 800 MHz (Band 20) Guard Band.
The MAX-BR1-LTEA-W-T covers Band 20 so does this mean that with the correct Vodafone NB-IOT SIM we could use a Peplink LTEA router to connect into the Vodafone NB-IOT network?
Rory
VODAFONE NB-IoT Customer Deck May 2019 Red v3.pdf (2.6 MB)
Hi all,
Does anybody has feedback on this feature (NB-IOT)??
Does anybody test it ??
Thx
V.
Any update on LTE-M?
And include it on the MAX adapter, from my tests LTE-M is super for OOBM of Pepwaves !
You won’t run Netflix on it but, Hey, it works! Also works fine for WebAdmin etc
Is lte-m ever going to be in the fw?
