Hello Together,
i am using a Peplink Balance 305 HW2 with 2 ISP in Loadbalancing. I have a problem with my Voip Telephone System Brand: Auerswald.
I have set 2 outbound Policys because the Voip System has 2 Lan Ports. The Policys are attached. I have fixed in the Policy that he use Priority Algorithm.
The Problem is sometimes the the Voip Module is using the ISP 1 and in the same time the other Lan Port from the Voip Modul is Using ISP 2. I see this in the Active Sessions.
Then Voip is not working because i can not heare something if i speak with someone.
