Hi I’m Doni form Jakarta. I’m new here
I have try to find out the benefit for “Load Balancing and SpeedFusion Bonding License Key for MediaFast 500”. As I compare specification between MediaFast 500 and MediaFast 750, I haven’t found any feature in Mediafast 500 that need add on license.
The MediaFast 500 does no longer require that license key, only the MediaFast 200 does.
The MediaFast 500 supports SpeedFusion Hot Failover, WAN Smoothing and SpeedFusion Bonding by default.
SpeedFusion Hot Failover enables you to switch between active WAN connections without any downtime.
SpeedFusion WAN Smoothing deals with packet loss by reconstructing lost packages.
SpeedFusion Bandwidth Bonding enables you to bundle multiple WAN connections to one fast internet pipe.
Keep in mind that all of these functionalities are based on VPN, which requires you to build a SpeedFusion VPN tunnel to a Peplink end-point somewhere, such as a Peplink Balance or Peplink FusionHub.
Hi Joey
Thank u very much for your explanation…
