I would like to test Layer2 VPN.
After upgrading the Peplink to 5.4.4, in the SpeedFusion profile, there’s no trace about Layer 2 bridging, bridge port, vlan tagging, STP, etc.
How do I enabled this feature ?
Regards,
Hedi
Regards,
Hedi
Hi Hedi,
You can enable layer-2 bridging based bonded VPN by clicking on the ? on the top right corner of the SpeedFusion Profile.
Stanley
Many thanks for your help.
I can play with this feature in my lab now…
Regards,
Hedi
Hello Stanley,
One last question.
Imagine that the switch port connected to the Peplink interface is a trunk (carrying multiple VLAN).
Can I enable multiple VLAN support on the Peplink interface ?
Regards,
Hedi
Hi Hedi,
The Layer 2 VPN does support bridging a trunk port across. You may try it at you lab.
Stanley
Hi Hedi,
I have made some amendment on my previous post. The Layer 2 VPN does support bridging a trunk port across. You may try it at you lab.
Stanley
