at what point does the information appear in the Fusion Hub GUI …/Advanced/SpeedFusion VPN in the attached image
Nothing appears here, this is where the profile config is displayed.
In this example you have a L2 VPN configured linking the untagged VLAN on this device.
oh thank you very much for the quick reply - so what is the VLAN and remote address field for?
VLAN is so you can use L2 VPN to bridge to and from different local VLANs (not just the untagged LAN).
Remote addresses is where you put the public routable IP of remote device that you are connecting to. You don’t have anything here so this device is acting as a hub wating for an inbound connection.
I am new to peplink, thank you for your quick reply
Ah yes this is your first post! Welcome to the forum!
You’ll find Peplink is a little different in their approach to some things compared to other vendors, and as you can see, there are a lot of people who like to help on the forums.
Have fun!
