Latency Cuttoff Speedfusion Cloud
Using Speedfusion Cloud on HD4-MBX with 4 x LTE-A Cellular WAN. Occasionally one of these WAN will drop to 3G drastically slowing the Speedfusion link. There is a “Latency difference Cutoff” setting under Speedfusion profiles but this setting does not appeaar to be available for Speedfusion Cloud?
Is there a way to set Speedfusion Cloud to drop slow links?
Does the signal drop also? Perhaps you can set your minimum signal to 3 bar.
I will try that.
Signal stays at 5 bar, Minimum signal does not appear to be an option on HD4 MBX?
How about setting them to “LTE-only” ?
