I need to check if we can use LAN port as WAN in MAX HD2 Mini Compact Dual 4G LTE Mobile Router
Currently we have 3 Ethernet ports for the device out of which we have 2 are LAN and 1 as WAN, so my requirement is to use 2 as WAN and 1 as LAN.
No you can’t it only supports a single Wired Ethernet WAN , but you should be able to use the USB as a WAN with a USB ethernet adapter.
