LACP with Peplink 580x
I just purchased a Peplink 580x. Was looking for the setting of Link Aggregation but cannot find it under port setting. Firmware is 8.1.1
Can someone point me to the correct thread ?
Hi, It should be the same as the 2500 under LAN port configuration settings.
Hi there Eric,
Thank you very much. Using Peplink 580x running versions 8.1.1
The page u suggested is not the same as mine. See attachment.
Thank you for the reply.
