L2 VPN Configuration Help
I’m looking for some guidance and direction on a layer2 VPN I’m attempting to configure with speedfusion, but I’m having an issue with the tunnel coming up. I deploy standard speefusion VPN’s on regular basis and have never really ran into any issues, but this is my first attempt at the l2 VPN.
Scenario:
Site A: Fusion hub
LAN : 10.238.10.0/24 (only network at this side)
Site B: Balance 2
LAN: 192.168.1.0/24
VLAN 10: 10.238.10.0/24
I’m wanting the L2 bridge to be utilized for the VLAN 10 network to transpire to the site A due to some software/equipment needs.
What I have done is create the tunnel from inControl which I typically do. I think connected to the site B balance 2 and added the VLAN2 interface as a bridged interface on the existing profile I created from incontrol.
VPN status goes from starting, building tunnels and then starts over.
I’m not sure if you’ve done this but I have followed @westnetworks video on Layer 2 tunnels over speed fusion with great results… Using B One 5Gs. He’s been kind enough to share this onto a YouTube channel https://youtu.be/KiFrxH46qM0?si=UWa50tsmDo_I6vWR… His video shows him using 3 different peplink devices to create the tunnels…I assume this would be the same using fusion hub…
Just a silly. Question here. But on your fusionhub location it appears you haven’t defined VLAN 10. Could this be your missing step…
