Is it possible to use a SOTG as the input for WAN2 on a Balance 310? If so, how is the SOTG setup?
I have mixed wired/wireless environment and would like to add the Jetpack/SOTG combo to replace the DSL connection I now have if it is possible.
TIA,
You want to connect as this way?
Users —> B310 (WAN2) —> SOTG )))Wifi as WAN))) Wifi hotspot —> Internet
Here’s what I’m asking about:
(users)
| B310 |
--wan1---wan2---
cable SOTG
(internet) |
JetPack (no ethernet port just wifi)
(internet)
Yes this is supported.
I would setup the SOTG in bridged mode and turn off it’s built-in WAP.
- Go to Misc tab to switch to bridged mode
- From the main settings page, at the very bottom you can disable the WAP functionality.
Jarid -
What, if anything, do I need to do on the Balance 310 side for wan2?
You shouldn’t have to do anything for it to connect
Jarid -
Thanks! And it was literally plug and play. Appreciate your help!
