IPv6 Unstable?
I ttried enabling IPv6 on my primary WAN through Starlink and suffered consistent but very brief outages. Enough to disrupt connectivity through tailscale and interrupt larger downloads that don’t have any issue over v4. DHCP connection method was SLAAC / DHCPv6. This is through an Orbit 8 with the original round Dishy.
I’ve not done any further testing yet as I needed to restore the network to stability. Have others noticed if IPv6 stability a general issue with Peplink given the lack of mature IPv6 implementation? I used SLAAC / DHCPv6 to gain the stateful firewall.
If IPv6 is unstable then I’m going to regret staying within the Peplnik ecosystem with the Orbit 8 upgrade. :confused:
@chaerd Could you please create a ticket at https://ticket.peplink.com/ so the Support team can check on the issue?
If the issue is firmware-related and occurs under certain IPv6 conditions, the Support team can work with the Engineering team to investigate and provide a firmware fix.
