I would like the Ping command from the Systems Menu (Balance Router Series) to include IPSec Tunnels in its ability to ping a remotely tunneled into network. As of right now the only way to check the remote networks ips which are active is to use a separate box with a ping command on it.
So as a future feature of Ping I would like to see this added.
