New MAX BR1 ENT. Shipped with firmware 7.1.0 build 3433. I want to upgrade to 8.0.1. According to release notes,“for BR1 series,” I need to first go to 7.1.2. I have downloaded fw-max_br1_br2-7.1.2-build3310.bin from the link in the release notes and also from your firmware download page but the upgrade fails each time with “invalid firmware image.”
May I please have some direction on this?
Steve
That seems to be the wrong firmware. You could upgrade from InControl2. Or use following firmware:
https://download.peplink.com/firmware/plb1/fw-b1_210hw4_310hw4_br1ent_transit_m700hw3_hd2mini_hd4-8.0.1-build4368.bin
The BR1-ENT does not need the 7.1.2 first. (Also via InControl2 for other BR1 devices, the 7.1.2 step is not necessary, only for the upgrade via the webadmin.)
Thanks for the prompt reply. It would also be very helpful if you could update your release notes so that others can avoid the problem.
Steve
Ok, I downloaded the update you mentioned, it passed validation but the upgrade hung at 79%. It has been setting at 79% for more than 1 hour. What should I do? I urgently request instructions.
Steve
Try to refresh your web page, login and check if Firmware 8.0.1 is loaded.
Sorry, false alarm. Just a screen refresh issue. The unit is up on the new firmware.
Steve
