This feature you can enable or disable. Does the peplink send any alerts concerning this when its enabled? (syslog or email or something else?)
Thanks.
Thanks.
I noticed this was removed in the latest firmware 8.0.2s089 build 4459.
Is there a reason or was it a mistake?
At some point it moved to the middle/bottom of the firewall config page. I’m on the code mentioned above and it’s still there for me.
