Intermitted connection drop - when one WAN fails
Hi guys
I currently have two Starlink antennas connected to my Pepwave Max HD4. When one fails the health check, even just for a second - this is noticed instantly in my network connection - even though the other antenna is still connected and working. Is there a setting that i can use so that only when both fail this is noticed
Iā€™m wondering if you may have had an opportunity to look at the recent webinar that pertains directly to the issue it seems you may be facing. The presenters are all experts with considerable experience. I think it may be worth your time. :<)
