As customers are organising their deployments per site, we are using groups to define each site with their own devices like router, external 5g/4g unit, switch and so on. Some or most of their sites requires the same redirections or blocked IPs.
Would it be possible to integrate the feature of grouped networks on an org level? It is bothersome to go through each one of the involved groups and update them individually.
Thank you for your support,
Maciej
Organizaiton-wide grouped networks will be added in the next release. Thanks for your suggestion.
Thank you very much for your help
