Claiming ignorance here. Thinking STP cabling was better. Reading about it now a few months after install and seems more trouble than it’s worth and can even cause more problems. Proper grounding being main issue
I honestly haven’t encountered any issues as far as I know but would like some advice.
I have 2 AP minis Poe wired to a Trendnet Poe switch. One ap mini has a 75 ft cable run up to attic installed top floor ceiling.
Other AP mini is installed about 25ft in basement ceiling.
The STP cable is connected direct to AP from switch. I do have metal shielded keystone Jack but decided not to use it for esthetics.
Should I rerun UTP cabling?
potential fire hazards without proper grounding?
Thanks for tips and advice
