I have a PUMA 401 and PUMA 020 that I intend to install on top of the bimini on my boat. Is there any guidance on how far apart they should be mounted and whether it is ok to install them on the same horizontal plane? In my case, I would like to install them as close together as possible.
Same question here. I have the Puma 410 LTE Antenna mounted. Trying to place the 020 Wifi now.
Should I mount the PUMA 020 upside down to get wifi in the boat?
