Dear Sirs,
Under social Wi-Fi (captive portal), is there has possible to verify types of Wi-Fi client login account?
(In device [Real Time] page or on incontrol2)
And i found if using same device to login with FB account after quota exceed then login as open auth will be associated with FB user not MAC address
Or maybe additional column to verify login type is possible?
Thank you.
Our Taiwan team will follow up with your on this.
Thank you.
Hi Stone,
Michael will follow up with you.
Eddy
Hi Stone, the login type has been added below each Sign Out button.
Hi Michael,
Is that possible to add extra column to display login type instead of below method?
Thank you.
Regards,
Stone
Hi Stone,
We will add an additional column for Login Type. Target to be available by today.
