I have an new InControl2 up and running at https://incontrol2.attrelogix.com but user cannot login, hit the error below…please help. Thanks
Please send the DeviceID that you find on the Control Panel to [email protected]. They will provide you a demolicence.
Just sent email, please review and provide license, thanks.
license applied, but still getting the same error, can you help?
It seems to be working now. Otherwise please try Ctrl-F5 or clear cache.
No, it doesn’t work. I’m using “Private Browsing” mode, should not be cache issue.
On the control panel, I find you have the option “Only Allow MSP Administrators to Create Organization” checked. I suspect you’re logging in not as an MSP Administrator. That’s why you see the problem.
OK, thanks for the tips, it seems to work now.
