I’ve been using the IC2 usage reporting which is great, only issue I’ve seen is we use many installs with dual sims, so one carrier in slot A and another in slot B, we can only report by cellular 1 on reports so it shows overall usage for both sims but what would be really useful is if it could break down by how much on each sim as its in use as this ties up with carrier billing/usage if we use multiple sims.
This is on our roadmap. Stay tuned.
That’s great news, thanks TK
Is this issue resolved?
If your devices are managed by InControl2 then there is a page for detailed SIM usage tracking and reporting:
I note that in a separate thread you are refering to access via the API, so the above may not be relevant to your case.
Cheers,
Z
