Dears,
In the InControl 2 the bandwidth monitoring is a really fantastic option, but unfortunately, I can’t see the IP addresses into the portal page.
Please let me know if there is anything I’ve to do in the BPL-210 setting.
Kind regards,
Yahya
Dears,
Kind regards,
Yahya
Can you post a screenshot of what you are talking about?
I have same exact issue with a B210.
Also there is another issue in bandwidth reports that there is no IP list in hourly, daily or monthly reports. You can see as below screen shots
Please open a support here for the team to check. You should able to get the DPI report after you enabled the feature.
For DPI reports, it may taken 1 hour for the first report to be displayed.
For Bandwidth Report, you should able to get the IP list in hourly, daily or monthly reports when you click/choose on the report date/time
Thank you,
Everythings going well after your help
