Hi Guys,
I just want to ask if this setup is possible, We have internal server as refer below (SA) and I want to access/connect to this internal server outside/public using the public interface assigned to interface01 used as point to point ip towards to the provider edge.
What I did is, Created a Inbound Access policy
Servers: SA-192.168.1.1
Service:
IP Protocol: TCP / "Protocol selection tool
Port: Any
Inbound IP(Connection/IP): ISPA / 111.1.1.1
Included server: SA-192.168.1.1 / Weight: 1
I would like to verify if my policy is correct and would not affect any services, Not that we also used this public ip 111.1.1.1 to access and manage peplink.
IP Protocol and Port May I know the difference of this two? On ip protocol selection if i did not select on “Protocol Selection tool” doest it mean its open to all or can we add new protocol selection that is not included on the option drop down?
What is the meaning of weight?
Since this setup is related to Video/Voice I would like to ask if possible to use this and Incoming traffic will be translated as planed?
Thank you and Regards,
