Import config from Balance 20 into Balance Two?
I am currently running a Balance 20. I want to replace it with a Balance Two to take advantage if the increased throughput. Can I import the config file from the Balance 20 into the Balance Two? Thank you!
No.
In the “olden days” Peplink provided a means to “convert upwardly” – e.g., from B20 to B210. Not now. That capability has been deprecated with newer devices, unfortunately. Having said that, your Peplink Partner may be of assistance in this.
