Is there a way to identify which cell tower my pepwave transit duo is connected to? Recently hard rebooted modem/router and when powering back up download speeds per speedtest were reduced by more than half. Would like to identify which tower connection is made.
Something like this?
If you click on the little blue “?” in the upper right corner of the “WAN Connection Status” pane, then you’ll see this …
Click on the “here” link and you’ll then see the information for which you may be looking.
Excellent. I didn’t know that was there either. Thanks!
I think it will be handy for me to be able to note if the cellid changes when using an omni.
Is there a good website/resource to locate a given cellID to a geographic tower?
