I need to pull a report from IC2 for a population of Peplink routers showing statistics from each router like 4G Carrier, Band used, Signal Strength, IP address, etc. Basically the information you see when you click on each device but in a table with all devices in a group/organization. Or similar to the information when you are in IC2 showing all the sites and you move over to the icon for a site that drops down similar information.
