i have peplink hd max 4 device and 3 wan connection with that . all are satellite WAN connections .
A 20 mbps
B 20 mbps
C 15 mbps
how can i get more internet speed for clients ???
is there anyway to get 55 mbps for clients ???
How many devices are connected to the device?
The problem with satellite is the latency so SpeedFusion Bonding will not be the solution.
Balancing works ok but the best option is to put users into different groups and allow the traffic to be spread across different links.
This is not a solution if its only a few people using the connections but works really well for larger amounts of users.
