How to deploy WDS
#1
  1. I am having the following network diagram
  1. We have 2 locations here
  2. The first location is A and the second location is B
  3. Location A will be the one that is providing internet connection and it has AC MINI A
  4. AC MINI A at location A will be getting dhcp ip address from its upstream router
  5. Its local mac address will be 00:1A:DD:D9:5C:DF
  6. Location B has AC MINI B
  7. AC MINI B is having local mac address 00:1A:DD:DA:EB:FF
  8. AC MINI B will connect to AC MINI A via WDS technology
  9. The 2 locations can be linked up without using the traditional wired backbone
  10. When the WDS is up, PC at location B will be able to use the internet connection from location A
  11. Both location A and location B will be inside the same LAN network 192.168.1.0/24
  12. WDS configuration at AC MINI A
  • Go to ‘AP’ > ‘Settings’
  • Fix the channel width to ‘20/40 MHz’
  • Fix the channel to ‘161’
  • Fix the beacon rate to ‘6Mbps’
  • Go to ‘AP’ > ‘WDS’ and click on ‘Add’
  • At MAC address field, put in the MAC address of AC MINI B
  • Save and apply all the changes
  1. WDS configuration at AC MINI B
  • At MAC address field, put in the MAC address of AC MINI A
  • Go to ‘AP’ > ‘Wireless SSID’ and create a wireless SSID
  • This SSID will be broadcast-ed at location B
  • PC at location B will be able to connect to this wifi ssid and go to the internet
