i’m wondering how to create spf(sender policy framework) record in peplink? i didn’t see any option to create it.
an SPF record is just a special type of TXT record. You can create TXT records for Blaance hosted domains in Network > Inbound Access > DNS Settings (on those devices that support inbound load balancing).
thank you MartinLangmaid
Dear martin, since peplink can configure the SPF, if my customer got this request, how we can configure?
they just send us below sentences and ask to update the SPF for them.
V=spf1 mx ip4:x.x.x.x ip4:y.y.y.y
Do u have guideline?
Go to Network > Inbound Access | DNS Settings and add a new txt record, don’t set a host so it sits at the root of the domain.
Dear martin, noted with thanks. Let me give it a try.
Dear Martin, thanks for the guidelines, as tested by customer it works.
