How to configure NAT of MAX BR1 Pro 5G for AGV?
We use MAX BR1 Pro 5G as the wireless access point for AGV.
The network segment of the factory’s wireless AP is: 192.168.3.x. There are 21 AGVs in the factory.
MAX BR1 Pro 5G wireless access point IP address: 192.168.3.102
A MAX BR1 Pro 5G LAN port is installed on each AGV and connected to a Phoenix switch (FL SWITCH 1008N). Under the switch are Siemens PLC (IP address: 192.168.1.101) and MRC equipment (IP address: 192.168.1.102) , and other equipment.
We have the following needs:
  1. The PC is connected to the factory’s wireless network (PC’s IP: 192.168.3.199), and the PC can enter the configuration page of MAX BR1 Pro 5G.
  2. The network ports 102 and 4840 of the PLC can be mapped out, but we have tried various methods to no avail.
  3. MRC network port 22 can be mapped out.
This is the first time we use MAX BR1 Pro 5G equipment. Because the configuration of this equipment is too powerful, we need technical support.
We are in Shenyang, China and can provide the contact information of a Chinese technical staff.
@zhenglin ,
Based on the description info shared above. This is more like a design and configuration required for the network setup. We may need to have the design diagram and other info in-order for us to help to answer your question.
Can you please create a ticket here for support team to review your setup and provide the advice accordingly ?
You can create the ticket by using the following URL:
