hello
how to allow 1 ip’s example i want to block the whole 192.168.0.0/24 to next interouting and allow the ip 192.168.0.100?
thanks
hello
thanks
This needs more detail for us to be able to help. Maybe a drawing of your topology to make the request clearer?
hello
for example from subnet 192.168.0.0/24 block to 192.168.1.0/24 but one ip exemption 192.168.1.100
thanks
If my understanding is correct, this should be the firewall rules that you looking for.
Hope it helps.
Thanks and regards.
ohhhh so mean first rule first priority will do try this thanks a lot
