How should it be setup
im after some advice if thats possible? ive got 2x MAX HD1 Domes, 1x Balance SDX Pro and a Pepxim SIM injector. ive also got a 15Mb 3rd party provided internet line. all of these are fed into a Meraki MX device, the 15Mb internet goes into WAN 1, and the peplink goes into the WAN 2 port of the Meraki MX. i dont think thats the most efficient way of operating, so am looking at having it so that the 3rd party WAN goes into the peplink, and then that feeds into the Meraki MX, however with how im currently setup i dont think that will make any difference.
ive bought 4 local sim cards, and got them plugged into the sim injector, ive got the domes plugged in, but am using the sim injector as its easier to get to the sim card slots. they are plugged into the Balance SDX Pro. however im getting very slow connectivity over the LTE (WAN 2) - i dont think that im using the bandwidth of all 4 cards, or even 2 cards. am i running in the most optimal way given the hardware that ive got? how can i improve bandwidth and speed - will getting SpeedFusion allow me to bond the 4 sim cards and the 15Mb WAN together? as i think that is ultimately what im after. is there a better way that i should be working?
