How many concurrent NAT sessions are supported by Peplink PL 21
@peplinkspecialist Pls suggest
I bet @TK_Liew knows…
@Gajanand, can you share the reason you need this? Are you facing any problem?
@TK_Liew Actually we are planning to upgrade one Cisco Router & i am suggesting Peplink BL 21. my client have one question as current router support 10000 NAT session & getting problem when this reach to peak. So i am asking this to cross check.
Pls suggest. Below is Router Log
T______________#sh ip nat statistics
Total active translations: 9477 (28 static, 9449 dynamic; 9436 extended)
Peak translations: 94778, occurred 5w6d ago
Outside interfaces:
GigabitEthernet0/1, GigabitEthernet0/2, Tunnel1, Tunnel2
Inside interfaces:
Vlan10
Hits: 3445297125 Misses: 0
CEF Translated packets: 3059098930, CEF Punted packets: 311520700
Expired translations: 373688043
I would suggest Balance 210 since 10,000 concurrent sessions is needed. You may contact local Peplink partner to get the details spec if needed.
Thank you.
