There is no obvious place under “Support” to initiate a warranty claim.
(Background: I have a B30 with a defective WAN 1 port - it goes up and down randomly, including after a factory reset. Tech support has not been able to identify the problem)
S
Tech support is trying to narrow down the problem. I suggest upgrading to firmware below then continue monitor.
http://download.peplink.com/firmware/plb30/fw-b20_30-6.2.3s012-build3064.bin
We will definitely process RMA if the problem related to hardware.
Thank you.
