I opened a ticket about a problem with my MAX BR1Mk2. The 2.4 ghz AP has stopped transmitting even though it shows its on. I need to get an RMA as its under warranty but support ignores my ticket. How do I contact Peplink to get an RMA?
Hi @ebourlet
Could you please confirm that the “Broadcast SSID” setting is enable user your wifi AP settings?
It can be found under AP → Wireless SSID → then click on the profile.
Otherwise, please post the support ticket number here and someone from support will follow up with you.
