Hi
I got an ipsec between 2 peplink over internet
By using the firewall, the internet access is now disable on the site B but the dns resolution is still active.
How could I disable this resolution?
In advance many thanks of your answer.
Hi
Assuming your users in site B are pointing Balance router LAN IP as DNS server. So you may disable DNS proxy via Network > Basic Settings > DNS Proxy Settings > Enable = Uncheck.
Hope this help.
