How can i see the GPS Data - signal strength and number of satellites
Dear Team,
How can i see the GPS Data - signal strength and number of satellites.
Kind regards
Matthias
you can see if you have GPS when you can see the map on the Dashboard.
In the API you see the following, but not the amount of satellites
Maybe @TK_Liew knows more about that?
BR
Dennis
Please refer here - GPS Receivers and NMEA Standards if you are using NMEA GPS format.
Thank you for your help and the Idea with the API. I will try to get all necessary information via API/Max.
Thank you for your fast response
