I have been trying to setup IPsec VPN connection with Cisco 2750.
So would you please help me in this?
Shall I have to have global static IP for my router from ISP? or can work without it? In the other end they have static IP.
If it work with out static IP, how can i know my router dynamic IP, and all other IP address that i should have to give to my partner to configure it in the Cisco router.
(i know it silly question, but i have not tech guy that support me). Please help me.
Is there any file that show how configuration is going to be made on Cisco side? Because they are new to connect with Pepawave router, they can’t do it.
Yea I have got your answer. Thanks a lot for your brief and detail explanation.
For those who want to know how please refer this answer.
work without it? In the other end point their is global IP.
–If there is only a static IP on one end of the IPsec tunnel, this is
ok, you do just need to use aggressive mode on the Balance setup. With
Aggressive mode only one side needs to point to a remote gateway IP
address. Local and remote IDs are used and must match and contain the @
symbol (ex.- balance@cisco and cisco@balance )
Do you have any file that show how configuration is going to be made on
Cisco side?
-As mentioned previously, I’ve attached our How to document for review.
Finallly, If it work with out static IP, how can i know my router
-See above regarding aggressive mode and IDs.
is it work with you, is the tunnel established by applying the configuration in that document ?
because i tried this configuration and i got that message on the Cisco router" Processing of Quick mode failed with peer at 20.20.20.2 ", and the tunnel not coming up
