Are any Peplink products that do WiFi as WAN receiving updated WiFi radio hardware with higher powered radios? Do all Peplink products use the same wifi radio / or have radios that are at the same power level? I am finding my phone has a slightly higher powered WiFi radio and can do a better job picking up WiFi signal at times than my MK2 which even has an external antenna mounted. I have been reading that some have had to get a Ubiquiti bullet or Mikrotik higher powered WiFi APs to use as WiFi as WAN on the WAN port because of the lower power of the built-in Peplink WiFi. Can someone from Peplink please shed some light? Is there a chart that breaks down WiFi radio specs by Peplink model with power levels (dB) listed. Thank you.
Please refer to this link and search for Transmit Power:
