Hello All,
I has multiple subnet internally and want to place two Balance devices to handle and route in multiple VLAN network environment. In Balance series, Can it support VRRP on multiple VLAN using VRRP?
Please advise.
Andy
Hello All,
Please advise.
Andy
The peplink’s have a native HA capability for that, which is essentially that yes.
They need to be the same model for the config sync to work between them. The base lan subnet is used as the vrrp subnet, and other vlans get applied to whichever device is active.
Bryn, I got it. Thank you!
