Help with video streaming and MAX-BR1-PRO-5G
Hello all
I own a MAX-BR1-PRO-5G. I am using Speedfusion.
I am feeding (in priority one):
  • Starlink via WAN
  • eSIM card installed in the device
  • WIFI (external mifi device)
I get slower output through LAN1 (which outputs speedfussion) than with the Starlink directly connected to my streaming device without using the Peplink.
How can I solve that? Which parameters could help me get reliable streaming with decent upload speeds, which is what matters?
Thanks a lot for your help!!!
Hello @pablofuente ,
How do you have your speedfusion configured? Are you doing failover, bonding, smoothing? It very much depends on your configuration.
