Hi all,
I need your help!
I have a peplink device 710 (BPL-710) using firmware 7.0.1 build 2094.
The device use two ISP providers difference (ISP A and ISP B), I created one outbound policy enforced for ISP A form source address (IP x.x.x.x) but tranport for ISP B.
- Can you share the screenshot defined outbound policy ?
- How you verify the traffic is send to ISP B ?
Do you have other outbound policy on top of this policy that possible overwrite the precedence ?
If not, please open a support ticket here for support team to check.
- I haved this policy of host (IP:X.X.X.X) on top in Outbound Policy
Host X.X.X.X outbound enforced via VNPT to 118.69.206.2 with any protocol.
Please find the screenshot below. Please route your IPsec traffic to the preferred WAN or disable IPSec NAT-T.
Thanks so much
My problem has been resolved.
Dear,
How to recover the configuration file of the 580 peplink device to the 710 peplink device and vice versa?
Converting a Peplink Balance configuration to another model can only be done by a Peplink partner.
You can best contact the company where you have bought the Peplink Balance.
