Help needed with port forwarding
This should probably be easy, but I am a first time user of Peplink and the router UI.
How do I setup port forwarding both incoming and outgoing paths in a B One, latest firmware? What menus do I need to use and what all do I need to enable? I think it is multiple settings involved to keep things from being blocked?
I have uPnP shut off and will keep it that way so have to manually forward.
Hi…
This URL will guide you.
