I have inherited a rather “special” network and have been getting it cleaned up. We have a Balance 20 router, netgear unmanaged switch and 3 AP One access points (set as bridge). I am having issues remotely connecting to and controlling computers connected to our network wirelessly. I can ping them without a problem but if I try to connect to \computer\c$ it fails. Admin shares are enabled. I try to scan the machine with spiceworks no problem. I try to remote regedit and I cannot connect. I try to push software and it fails. This only happens to the machines connected to our network wirelessly. It is a combination of Windows 7 and XP machines. Suggestions?
Also, we have 2 wireless networks, one guest and one internal. But both networks are using my windows DHCP server and I have come close to running out of addresses. Can I give the guest network a separate DHCP range using the AP One DHCP option?
Thank you for any help / suggestions
David
