Help in choosing Peplink equipment for commercial vessels
I represent a small company that provides services in the field of marine communication solutions on ships.
As part of the modernization of our communication network, we became interested in solutions based on Peplink devices.
At the moment, we have a Mikrotik Router (CRS125-24G-1S-2HnD) installed on our ships, paired with a small “server” that controls it, switching WAN sources and counting traffic. All this is controlled by our own system, which is significantly inferior in capabilities to the Peplink InControl system.
Our ships are equipped with Iridium, VSAT, LTE (near the coast), and now we are actively installing Starlink.
In addition to Internet access, several WiFi networks (crew and business), VoIP telephony, sometimes video surveillance and TV are deployed on ships. We also have our own fleet tracking system.
We paid attention to Peplink devices, as they take into account the specifics of marine solutions, have a good interface and high potential for integration, can switch WAN sources and take into account the features of managing expensive satellite channels.
We chose the Peplink B-ONE-PLUS-L router as a replacement for our “server”, due to the presence of LTE, several WANs and the ability to switch them given the cost of satellite channels, but we doubt the correctness of the choice.
Thanks in advance for advice,
Sincerely,
Denis Zhurbenko
The B-ONE-PLUS is a great choice. Having a single cellular CAT-4 Modem may limit your throughput depending on the data plan, and strength of the cellular signal as the vessel moves away from shore. Can you gage the number of active users/clients on the network? This will most likely become your limiting factor considering the devices you have mentioned and the potential of users to require streaming with certain applications.
Here are some good case studies to review to see if your application is similar. If so, the equipment listed in the case studies may be a more ideal consideration.
Cruising with Passion
Red Sky SY
River Cruise Internet
If you would like to have a more detailed discussion I’m more than happy to join a call meeting to review your deployment topography and use case.
