I had a BR1 ENT previously which was set to 172.31.3.1/24 that was just used for fail over to cellular with a few wired devices connected directly to it. WAN1 was connected to Google Wifi which has 4 access points and functions as a router, since that can’t be disabled. The Google Wifi is 172.31.1.1/24. Previously if I was on my desktop wired to the BR1 and assigned IP 172.31.3.100 I could ping, or remote desktop into a computer on the Google Wifi at 172.31.1.40.
I changed the BR1 for a HD2 with the same 172.31.3.1/24 assigned as previously, but now the 2 networks will not talk to each other. I can’t ping or access devices on Google Wifi at 172.31.1.1/24 from my desktop at 172.31.3.1.
Is there a setting or something somewhere I’m missing? I have inter VLAN routing enabled if that changes anything, even though there’s no VLANs in use. If I go back to the BR1 it works fine so just not sure what is off. Thank you.
