Just wanted to clarify something, I understand that in warranty products provide access to InControl2. On the Peplink store there’s part #s for InControl2 access but it shows only entry level devices like Balance 20 and 30. Just wanted to confirm, the only way to keep using InControl2 after the warranty ends is to buy a new warranty? Is there any way to use InControl2 without an extended warranty on the HD2 or Balance 305?
The two main options are to keep the devices in warranty with Peplink so you can use the Public Cloud or to buy and host your own Private IC2 appliance.
The other option is to find a partner in your region that already hosts a private IC2 appliance and rent a subscription from them.
