I use an old Pepwave office point with 2.1.6 firmware. It’s still supported the Guest portal?
Thank you
Thank you
Pepwave office point was obsoleted and no longer supported. Please consider refreshing your hardware. Please check the latest model here.
thanks for the reply.
But I see that the https://incontrol.pepwave.com/config.php portal is stil active.
The original InControl platform will be going EOL as we have migrated over to the new InControl2 platform.
Is my old device supported by Incontrol2 platform?
The old hardware no longer supported by InControl and InControl2. Please consider refreshing your hardware.
Thank You
