Hi All,
Does someone know at what time the Captive Portal guest account quota reset happens if you set it to 1 day?
We have a situatie that it needs to be reset every day at 00:00 at night.
Maybe a good feature to implement reset every day at a sertain time?
Thanks!
TK_Liew
2
It will be the next day after the user log in. For example, user logins at 13:00 today, then the session will be reset at tomorrow 13:00.
Will it be possible to implent a feature to select a certain time on a day?
Yes, I would also prefer to select the fixed time (00:00)
I had what I’m pretty sure was a bug with this a while ago, when set to 24 hrs when devices reconnected the next day it didn’t work properly.
I’ll try and re-create it.
